ironbuttjohn
Hi Tom
You know me, NO
You know me, NO
Run the pipes out just behind the doors. These pipes are '36 Ford driveshaft halves, one on each side, with 8" motorcycle baffles fastened in the end of each outlet. Very respectable around town as long as you don't stand on it!
I have a nearly stock 40 Ford motor in my 32 project with the exception of a pair of Reds headers (so I'm running duals) and a "Y" adapter for 2 deuces running progressive. Since I have little to no room to go up and over the axle, I will probably exit to either side around by and before the rear tire.
I know folks on here have said they run no mufflers but I'm just wondering if that's more the exception than the rule? I have a pair of tube glass-pack baloney-style mufflers but they can always be used on another project.
What do you all think??
