My centre perforated tube was rattling inside the support baffles because it had become detatched somehow. I don't know where the muffler came from or who made it. It was on the car when I bought it. I Drilled a 1/4 inch hole in the case, looked in with a light probe and could see the problem area. I thought the centre tube would get hotter than the casing and expand more and need to slide inside the supports, but it was welded to the one I could see, and the weld had broken.
So i sharpened a long 1/4 inch bolt, welded a 1/4 inch nut over the hole in the casing and screwed the bolt in until the point registered in one of the perforations in the centre tube. I lock-nutted the bolt against the welded-on nut. After about 1000 miles it loosened , but after tightening it has been quiet for another 10000 miles. It allows the tube to expand and slide, but still traps it in against the baffle.
It saved the price of a new muffler and cannot be seen, since it is at about 11 o-clock on the casing viewed from the front.
A pragmatic solution, not to purist's tastes. But the muffler was very sound and solid - just badly made internally. I painted the whole exhaust with phosphoric etch (Dulux Deoxidine) and then painted it with black semi gloss barbeque paint (rattle can). It still looks nice, though I touch it up now and then and wipe mud off it while up on my hoist. I use stove black on the exhaust manifold too - rubbed on every couple of months or so. A 5-minute job
The muffler has a nice Model A sound, with a bit of a "whoofle and tweet" when idling fully retarded.
I am not sure whether it should actually sound like this, but they all seem to sound different and mine sounds very "vintage" when sitting at traffic lights and echoing off other cars.
It has a 5.5 Snyder head and Stipe cam from Schwalms, and I guess this changes the sound.
Regards from SAJ in NZ
