Pilotdave
I'm curious about gasoline consumption. As a newbie Model A (1930 Tudor) driver I'm hoping that the experts can shed some light on what I should expect for mpg.
First, I have to confess that I haven't been keeping careful records, partly because our odometer was not functioning until repaired over the winter. And I did not note how full the tank was before starting to drive the car this spring. I'm guessing it was between 1/2 and 3/4 full when we put it away for the winter. Yesterday the gauge said we had 1/4 tank - took 7.26 gals to fill it. Distance traveled per odometer is about 40 miles. If we started with 1/2 a tank and ran it down to 1/4, then we're getting 16 mpg. On the other hand, if we started with 3/4 tank the mpg is about 8!
Some other data: no observable gas leaks or gas odors when sitting in the garage; spark plug centers are light tan with no carbon buildup anywhere; tail pipe is a light gray color. So gas isn't being lost to leaks and the air/fuel mixture must be about right.
Is there some other way to lose gas in a Model A? I'm wondering about evaporation loss in a car that has sat for several months.
Needless to say, I'll be watching this carefully as we drive the car this spring. We plan to use our gps to monitor the odometer once we get going. In the meantime, I'll appreciate any advice!
