34 fordor owner
I was able to get my dome distributor off my 34 flathead and out no problem without removing anything extra. Now I got the distributor back and can’t get it to line up properly to be able to mount it. I need some tips.
Turn the rotor of the distributor until the tongue on the back of the distributor lines up with the offset slot in the end of the camshaft in the hole in the timing gear cover.
Make sure you have the ignition switch ON for your spark test. Regards, Kevin.
For future reference to folks.
I was just catching up with Mart and his Pendine Prep series. This one is video #7. Between 21:30 and 23:00 you get an excellent visual description of him fitting a distributor tang into the slot in the end of the camshaft. First pic is the wrong way, second is when the tang dropped into the slot. Later in the video he dresses the tang to get an even better engagement.
Maybe it will help someone else.
Nice job Mart!
the video: https://youtu.be/Ydy38R7EPL8
Mart's thread about the video: https://www.fordbarn.com/forum/showthread.php?t=311700
Mart's YouTube channel: https://www.youtube.com/channel/UCzcePXyhzVro40j-vjjZShg
Make two temporary studs and put them in finger tight. This will allow you to slip the gasket on and then the distributor. Turn the rotor with your finger as you line up the slot and slide the distributor in. Install the third bolt and then replace the two studs one at a time with the permanent bolts. Easy-peasy.
Hi,
Planning the replacement of the V8 dist.
Could someone provide size for studs (diameter, length) so I can prepare for easier fitting as suggested above ?
Many thanks
