pjdeb Senior Member Nov 16, 2024 #1 When mounting a new radiator, are ther springs on the top and bottom sode of the bolt? Just on the top? Just on the bottom? 1923 coupe
pjdeb Senior Member Nov 16, 2024 #3 With two springs on each stud 2 7/8 it is a ***** to get the castle nut on. Tough to get a prybar in there to lift the lower plate to the point where lower spring is compressed enough to get castle nut on. Can the 26-27 studs 2 3/8 be used?
stevests Well-known member Nov 16, 2024 #4 Check this out, if it attached - http://www.mtfca.com/discus/messages/506218/505806.html?1420667954
