Mounting 35 1/2 ton Truck bed Correctly
Benton 35
New member
Good Morning Ford Barn
When I dug my project out of the weeds the bed was in such bad Shot full of holes and rusted away I left it on the huge nest of ground dwelling Hornets Dam that sting lasts for hours so I never saw how the bed was mounted and where Mr Ford wanted the WOOD BLOCKS I purchased the pair from Dennis Carpenter and was impressed on just how purpose built they are so they must go in one perfect spot and lock into the bed with that top dove tail looking piece.
Does any one have a photo, or a web site that shows how the wood blocks fit on the frame I have the original steel bed over a marine sheet of sealed plywood, Just want the bed to look and fit right and what kind of mounting bolts and rubber pads did you use that would be great. Thanks Ben
You should post this question in the V8 forum, rather than the Model A forum. Those guys should have more knowledge about this. Good luck with your project and welcome to Fordbarn.
Dam Thanks Lenard S
I Just Retired after thirty years running Tower Cranes now I learning to post Oh dam run. Hanging Iron was easier. Thanks Ben35
