Motor question.
mickeyc
Hello everyone. Mickey C here. I have been a Hamb member for quite a
while. Several years ago I bought a 31 Model A coupe while in California.
It is an original car with a knock in the motor. This did not concern me as
I planned to hot rod this car. Now I have changed my mind. I have begun to
appreciate the little car for what it is. Now I find my self beginning to prepare
for a sympathetic repair and refurbish with out a full blown restoration.
To that end I have acquired a complete Diamond block motor that is said to run very well. I removed the fill tube from the block to look into the crank case. I did not observe the tray in the oil pan that retains oil for the rod ends to did into for oil distribution. I have seen reference to this appliance in 28
and 29 motors. My question is should this later year replacement motor have
this item in the oil pan? I have not looked in to the original motor as of yet
to see if there is one in place. This concerns me a good deal because I understand it was an important element in proper oil distribution.
Thanks for any tips or information anyone may care to share with me.
I am excited to get the coupe running and drive a lot.
The dipper tray is how the rod bearings get oil in a stock engine so you wouldn't get
very far if it was missing.
Hi Mickey.
Like Bob C said, that dipper tray is pretty important.
You may have to buy an entire oil pan assembly to get a tray.
The oil pans do differ a bit. Earlier pans have a removable round plate on the bottom (oil pump access), and the later ones don't. I think there was a dipper tray height adjustment made by the factory at some point too. Its good to research this before you fix or buy something.
Good luck.
If this motor runs very well, that means it’s been run. If there is no dipper tray, then it should’ve burned up. I wonder if you have a pressurized oil system. If you were to pull the oil Galley/valve cover, then, if it was full oil pressure you would see the plumbing.
Thanks guys. I have had this A for several years and am just now getting into
making it serviceable, so I can tool around town in it. After again pulling the
oil filler tube out of the block and looking more thoroughly I in fact did see that the
drip tray appears to be in place! This was a large relief! Now on to several more issues
I have identified. Most are strait forward and understandable. I am sure I will have
many more questions and appreciate the response from the knowledgeable members
here.
Hello Dave. I did speak with you regarding the Galaxie. I also regret not buying
the car. Your workmanship and attention to detail on the Galaxie was superb. As
it happened I had some serious family health issues arise at the time. This caused me
to hesitate on pursuing the purchase further. The time to buy something a person
wants is when you see it. I would think the new owner is enjoying that hot rod
very much.
