I am replacing the radiator in my 1931 fordor slant and decided it was way to easy not to replace my fan belt.( should have known nothing is easy in my world!) I had trouble removing the belt from the bottom pulley and finially got it off and tried to slice my thumb off with the fan blade. I felt underneath the pulley and found the rubber or leather not sure washer real loose on the motor mount. I also tried moving the washer around to the flat side thinking that was the problem with the removal of the belt. there was no flat side to the washer as shown in the shop manual. My dad installed this motor in 1973 and I am guessing he made most of the parts or made do with what he had, since there was no easy supply of parts back then. Also missing is the spring on the bottom side of the front motor mount. It just has a washer,locking nut and cotter pin. the springs on the top of the frame seem to be completely pushed down. I am guessing that the springs are wore out and it is makeing it too hard to put the belt on. I have also noticed that the pulley is just barely rubbing the front motor mount. I have ordered a new spring set to rebuild the mount. My question I guess is I am thinking about trying to raise the motor ever so much to get the new belt on so I can have it for a wedding in a week and then replace the springs. Is this ok or do you think this is what is causing my trouble with the rubbing and trouble getting the belt on? I have replaced the belt at least one other time in the last 15 years and had no trouble.
sorry if I am rambling, this is the first time in over 30 years this car has not run and really wanting it back on the road.
thanks for any help!
