DRG-ler
Hi folks, we are currently looking at the bug.
It's about a Tudor with a 4Banger, where the engine doesn't pull properly. There is a lack of power, so that the car can only drive 70/80 km / h. Far too little!
What has been done so far: We found sand in the tank. I have no idea how it got there, but we dismantled and cleaned the entire gasoline system, including the gasoline tap, sight glass, all filters and carburetors. That was unsuccessful!
The gasoline flow was controlled. Unsuccessful!
A complete replacement carburetor was installed, from a Tudor that runs at full power. (Would drive 95Km / h if he had to.) That didn't change anything either. Unsuccessful!
The ignition system was set using the Nurex Precision Timing Kit and ignition flash gun. Also brought no change, unsuccessful!
It was recognized that sparks flash over on the distributor body. An intact one was installed, but that did not lead to any improvement either. Unsuccessful!
New spark plugs were installed. Unsuccessful!
What could be the reason for the lack of performance? The engine runs very smoothly and smoothly, starts very well, but it is already evident when accelerating from the lower revs that it lacks power. I'm slowly running out of ideas.
Greetings from Berlin
Andy
Andy
