Screws on the originals are ornately scrolled with good detail; repros are plain.
No, You can change the screws !! All you have to do is find a bad one & make the switch.. The best way is... all Original ones had the stems nickel plated & with a very small plug @ its base.. The re-pops are all solid brass & not plated..Yes the screws are the easiest way to tell.
