pooch
I believe motometers are designed to read from the hot air/steam above water level.
I never see the MM gauge rise , there is an accessory temp gauge fitted and it shows 140 F max up a hill.
Probably typical non-thermostat temp.
I have seen mentioned, some have extended the heat sensor, so it dips in water.
Does this work, or is it a waste of time?
I assume the way to go is, piece of copper pipe and fill it with solder, and leave a 1/2 inch out on top and crimp it onto motometer using heat transfer paste.
