Mostly 1935 - 1936 ford pickup parts
CA Victoria
Templeton
Ca
Price
25-up
Pickup Windshield frame, missing hinge brackets. Old chrome that is peeling. Has one rust spot inside the glass channel, otherwise in good shape.
$250 - pickup only
Lower cab repair sheetmetal panels. Professionally done for an exact fit. 2 corners and lower back panel. In epoxy primer. $450
35-37 Cab wood blocks. Originals in ok shape although will need some repair. $125
Inner fender panel. Will need work but saveable-$50
35-40 pass or pickup lower frame splash apron. Fits below the radiator in between the frame horns. Original-Good shape. $100
1935 pickup - early cab inside window frame for RH door - $65
1935 NOS FORD ignition coil in the box
$125
46-48 NOS Ford - Wizard brand ignition coil in orig. box. $80
34-36 exh manifolds, very nice shape $100
1935 Distributor core $25
1935 fuel pump core. $25
NOS Ford 7 spark plugs, later 1pc style in orig boxes $80
NOS Ford script shock links, correct for 1936, will fit 35 or 36. Set of 4-$100
Brake drums. Turned oversized but good cores for re lining. $50 ea
Photos on request.
If the ad is up parts are still available.
Please respond with your phone # so I can sort out the scammers.
Shipping at buyers expense. Small parts will go USPS flat rate,
Larger items will be pricey to ship. Suggest local pickup arrangement.
T.
