No one mentioned to check the type of secondary well; there are 3 types; I prefer type 3 as its undercut at the location of the tip of the compensator jet. Also check the small hole at the top of the secondary well to be sure its open. Also be sure the air idle adjustment needle completly closes off when the needle is seated; some of the replacement needle tips are too short and don't reach the seat.
I do not know which type well was installed but the openings on the secondary well were open. I had soaked the well in carb cleaner and then blew it out with high pressure air and observed the openings to be clear.
The needle to seat seal was checked and it was good...the carb body had a replaceable seat installed.
Ron, From your experience, what benefit would the type 3 secondary well with its undercut have in the average performance of a carb over the others? Thanks...
Good Day!
Dave in MN
