Dave in MN
Greetings all,
I have a Zenith -2 Carb giving me trouble. The darn carb causes any engine I put it on to backfire upon quick let-off of the accelerator. Over the years, I have rebuilt many carbs and always flow test the jets, clean out the passages, follow Steve Parteger's booklet guidelines and refer back to Moler's book and the Model-A.org info on line when necessary.
The jet settings on the carb giving me trouble are: 168ml/mn on the main jet flow, 142ml/mn on the compensator jet, 44ml/mn on the idle, 170ml/mn on the cap jet and the float is set to provide the correct fuel level height when measured with an outside sight level tube.
The carb idles great, the mid range power is smooth and strong. The top end power is good. The GAV adjustment (closed to 2-3 turns open) causes no change in the backfiring problem. The GAV causes the typical reactions to adjustment when the engine is cold at start-up but limited change once the engine is warm. This would typically indicate a lean condition. My next step is to oversize the main jet to see if it will correct the problem but.... With the jets I have in it...it should not be lean unless something else is entering into the picture. Slightly choking the engine is real difficult to do when driving and letting off of the gas quickly...I can't tell if it helps much.
I have two Model A's with very good running carbs. When I switch their carbs to this particular owner's car the car will not backfire. Likewise when I switch this offensive carb to one of my vehicles, it will cause backfiring on my A's. The problem must be in the carb...but what am I missing? Thanks in advance for any help offered!
Is there such a thing as a "devil" carb?
Good Day!
Dave in MN
Good Day!
Dave in MN
