Deluxe Delivery
When I look at Marco's picture of the distributor used to set the timing, it shows, and says that the rotor is just about to contact the #1 contact tip, the points are just about to break, and the cam is just starting to be at the high point. This is to occur at the 4 o'clock position. Yet in my current situation, when I set it all up...I am closer to about the 3 o'clock position and the rotor has already passed the #1 contact tip. What do I have here? twisted dist shaft? I can't seem to get the timing right. What am I doing wrong ?
