Bob Johnson
Here are two sets of temperature data. The two tests were done going the same route. The ambient (air) temperature for both runs was 60-65 degrees F. The route started with city driving and at about the 5 minute (5:00 on the graph) I was on the highway going about 50-55 mph. There are 3 hills on the route. You can see them as the 3 peaks in the lines. The second hill is the steepest and shows the largest peak in the data. The in city data (before 5:00) is not comparable because in one run I had to stop at 3 traffic light and in the other run I made it through all 3 without stopping. So only look at the data after the 5:00 mark. Once the engine gets up to temperature the non-thermostat test is showing a lower temperature than the one with the wired open thermostat. The difference is about 10 degrees when the ground is fairly level. The difference increases to over 20 degrees when there is a hill to climb. Again the thermostat in the "green" test was "WIRED OPEN" so the difference has nothing to do with the thermostat opening and closing. I believe that the difference is due to the thermostat restricting the coolant flow.
I will post data from more tests as I complete them.
Bob
Bob
