jerseyboy
We'll I figured out that I needed to replace the shackles on the rear spring, and that I wanted to reverse the eyes on the front spring on my wagon.
I read a lot of the threads on removing springs and spring spreaders.
All that info left me a little confused and nervous(first time).
Well I liked Heard's and Jim1932's threads and found a link that Tinker had posted by Harmsway on the HAMB. The thing I liked best was that Harmsway posted a step by step with pictures
http://www.jalopyjournal.com/forum/threads/re-visiting-the-very-cheesy-1-79-spring-tool.646689/
Harmsway used the all thread method with c-clamps.
I also borrowed a spring spreader, just in case.
•The frame was already jacked up, so I unbolted the spring and axle and let it pivot down to were I could get the all-thread thru the center bolt hole.(wheels removed)
•Clamped spring with c-clamps.
•Unbolted center bolt.
•Put in all thread, washers and nuts(I had two nuts on each side). Tightened nuts.
•Clamped 2x4s on each side of the spring to prevent the leaves from twisting out.
•Removed c-clamps.
•Slowly loosened nuts and made sure bottom nuts were not walking out. I had to keep moving the "lock nut" on top so I could loosen the second top nut.
•Removed all thread when spring pressure against top not was gone.
•Removed leaves.
•Removed shackles.
I have to say, I really like this method and I will not be needing a spring spreader!
Pictures below.
Thanks to Harmsway and Tinker.
Keep V-8ing and 4-banging!
•Removed c-clamps.
•Removed leaves.
•Removed shackles.
Pictures below.
