RalphG
Got the new "long distance" 25 litre plastic fuel tank installed in the trunk of the Merc. Should give me a little more range than the gallon just under the hood. Safer too. As of tonight it also has working dash lights. Just needed to wiggle the switch the right way. Unfortunately I could not improve on that off idle stumble that the Holley is plagued with. It will literally stall out unless I pump the gas pedal carefully. Timing adjustment made no difference so I'm suspecting the power valve now.
