51PanelMan
I have a 49 ford panel been in the family since 1949. was a bakery delivery truck. Five years ago my stupid uncle tried to put an s10 frame under it. cut up the orig frame fro scrap, gave up on the s10 frame and dumped the truck in my yard. would like to find an orig. frame. Know where I might find one? rrob
It would be nice to know where you're located so we can help you look.
I just sold a frame from a 49 Panel truck for $1100 (no motor or trans). It already has adjustable rear leaf spring shackles, new rear leaf springs, Fatman Fabrication MII front end and has been boxed. I was going to use it on my 51 Panel, but decided against it. I've had this frame in storage for over 4 years.
Keep checking your local Craigslist, newspaper ads and eBay. You may find a parts F1 truck or Panel for $500. The frames between F1 trucks and Panels are virtually the same. The only differences is that the truck frames have six running board brackets (3 per side) and rear cab mounts. The Panel truck frame has four running board brackets (2 per side) and only the front cab mounts. The running board brackets are different between a Panel truck and a conventional truck. Running board brackets on a Panel are longer to accomodate for the short running boards, while conventional truck running board brackets are shorter to accomodate for the longer running board. Additionally, the fuel tank fits inside the frame rails on the left side directly after the brake master cylinder.
Panel truck running board bracket is on top. Conventional truck running board bracket is on the bottom.
Panel truck fuel tank and frame brackets (specific to Panel trucks only).
Finally, not to add salt to your wounds, I scrapped a 50 Panel truck that had a complete frame. I couldn't sell the frame for the longest time and I needed to clear the trailer space.
