On a Model a engine, the oil pressure gauge reads the resistance of flow between the gauge port and the discharge pipe in the valve chamber. The higher the flow rate (RPM) and the higher the viscosity the higher the gauge will read. The pressure to the bearings will be the same, a gravity pressure of about 6" of head or about .2 psi. 100 psi on the gauge will not give you another ounce of pressure to the bearings, the gauge is just letting you know that the oil pump is still working. The model B is different critter all together.
