More head removal guestion
i.set_a
I made that head removal tool. Isn't working. It is lifting the right side and not the left. The spark plug holes and the 5 studs used for the puller are on the right side. Makes since that is is lifting that side. Of course I haven't lifted it over about 1/16 to 3/32". If I keep lifting will the left side come on up? What do I need to do, just keep on or something else?
Had a similar problem once. - just squirted plenty of penetrating oil on all the studs and left it chained under tension overnight. On returning to the garage the following morning glad to see that it had freed itself. ( Try not to resort to force except when beating an olive tree or wife.)
