More F1 clutch questions
medctr1
I have a 1949 F1 239 flathead with a crash box non syncro 4spd. It had a 10inch clutch,but it seems that the 4spd should have come with a 11inch clutch.Should I change to an eleven, would it be more original.....advantages?
+since it is doubtful that you will be hauling a heavy load, you won't need an 11 clutch, 10" is just fine, not completely sure your F1 even with the four speed came stock with an 11", I am sure it could have been special ordered.
My 49 F1 came out of the factory with the heavy duty 3 speed box (synchro 2nd and 3rd and lower 1st and 2nd gear ratios than the lighter duty box) and the 11 inch clutch and pressure plate. I looked at mine after 38 years of driving and there was no noticeable wear. Some say this is a much heavier clutch than the 10 inch but I have never found it so. The 10 inch will be fine for standard driving with the 11 inch more suitable for heavy haulage.
My 48 F1 came with the 11" clutch also - and I agree with the guys about the 10 working just fine unless you make your truck work hard like mine has to.
My engine came in a new F3 purchased in 1950. It had the 4 speed crash box. The truck was used for heavy farm work all its (first) life. When I tore it down for rebuild I found it had a 10 inch clutch. Used hard from 1950 to 1968 and never a clutch problem.
