More 39 pu questions please?
malpais
Got two kinds of hub caps. Pretty sure the round ones are for the 39 pu. The others, flatter with a ridge around outer most edge
Also,found a 46 Merc hub cap if someone needs one.
One on the left is 39 pickup , center should be Stainless, looks like it was painted with a brush ,HA. I have seen them for sale around the net for fair prices , I think some vendors have new one's as well .
472901
Here's a couple on my wall, first a 1938 Ford Standard with a long V-8 across the stainless, next the 1939 Ford Standard with a shorter V-8 and Blue color instead of Black. Both caps have the same steel base, only the stainless is different if that makes sense.
Someone has obviously drilled a hole from the back side in order to pop the stainless cover off with air pressure. Hopefully they did not drill through the stainless cover as well, and ruin it.
472934
1938 Ford Standard Hubcap. Notice that the V8 is larger in the 1938 Ford Standard and is smaller in in the 1939 Ford Standard.
Thanks for all the info. I see eBay lists both styles for 39 pu. They may be taking a wag tho. From your photos, most of mine are 39 Ford deludes, and a few 39 Ford standards. Got more of the ss parts for the deluxe SS so will go that way.
An old farmer left a 37 coupe crumble to nothing in his woods. Thought maybe I got a few off of it.
Really appreciate your time and knowledge
Gordon
