Kaonix
Hi guys, heres the skinny.
Car: 1941 Original Flathead 8
Problem: Car starts beautifully, runs BEAUTIFULLY then after driving for 10 to fifteen minutes car dies and wont start for an hour or so, coil is HOT to touch.
Parts:
12v NEG GRND Battery
Mallory Electronic 3 bolt replacement dist. #5072101 from Speedway Motors
First Coil: 12volt chrome job from autozone - Suspected Dead
Second Coil: Mallory Promaster 12v #29450
I have basically eliminated the vehicles wiring harness from the equation, I've sourced 12v from the battery for diagnostic to make sure I'm not missing any resistors or anything, I have the wiring correct from distributor to coil, only change is we have a dakota digital dash that requires a wire from coil - for tach lead.
The car runs ridiculously strong for ten to fifteen minutes then just dies. No sputter, no jerking, just dies. Fuel is fine, running electric pump with a regulator that is flowing perfectly.
I have tried running with the original ballast resistor under the dash and without. I'm assuming this new coil is internally resisted, it is the recommended coil by mallory to use with this distributor.
PLEASE. ANYONE HELP ME!
P.S.
I don't need any wise comments regarding how great six volts is and that I should have left it. If six volts is so great, manufacturers would still be using it. I like being able to see down the road at nite.
Parts:
P.S.
