Tom,That's the first thing I do to caps and rotors, is washer them with a brush and soap and hot water. Then I store them in my basement, but they will get moldy after a couple years, so I have to keep wiping them down. I wonder if there is any product to prevent the mold?
Check for a good spark by holding the coil wire 1/4" from a head nut.
No use doing a carb if the problem is spark.
With the key on and points open, do you have 6 volts on the points movable contact?
with the points open at the moveable point arm you should read 6v.
with the points closed you should lose the 6v
if not the points contacts are dirty or bad
what do u get with the points closed at the same location and key on?
as posted im #31 if you still have 6v when closed key on then you either have bad or dirty points or a bad ground to the distributor such as paint causing a poor connection but that scenario is very rare...
I get no voltage with the points closed, only when open. Is this "Witt's End" for me?
I think Miss Tillie is going to "stand me up" for Saturday's Car Show. "Stood Up, Broken Hearted", more than one person can handle.
