bogiediver
I ordered some new 1 bulb headlight sockets from one of the vendors.
When I received them, the packages were marked 1 bulb headlight socket; but, the packages contained the 2 bulb headlight socket.
The vendor said just cut and remove the parking bulb socket & wire and it's essentially the same as the correct 1 bulb socket.
A thought occurred to me - most headlight threads talk about making sure the headlight bulb is grounded really well. What if I cut the tip off the parking light wire at the socket end, remove the parking light socket; then solder the parking light wire to the back of the headlight bulb socket (making sure it does not interfere with the focus screw).
Then I could add my own 3rd wire to the plastic wire plug at the conduit end of the pigtail, running the wire thru the conduit to a good grounding point.
Anyone see any issue with doing it this way? Since the tail end of the socket, where the wire plug goes, is designed for three wires – it seems like a clean way to accomplish the grounding…
Thoughts…
Thoughts…
