Seth, please let me ask you to qualify your statement above.
I know you say there are a lot of "neysayers" here but many of us have spoken based on our personal experiences with them. Again, if you would be so kind, could/would you explain why you feel they are better?
Brent, Your request is really valid to the point that, if Seth is occupied with other matters currently, I will try to answer with, what I feel are, the qualifications.
1. Points must be adjusted. To wide, weak spark. To close, burnt points.
2. Points are operated by a friction block that rubs on a cam.
3. New points are prone to lose adjustment until the friction block is seated.
4. Point gap varies with any play in the distributor shaft.
5. Points transfer material with operation which causes pits and peaks on the point surface and can cause difficulty in gapping.
6. Points use a condenser to control the arcing when the coil field collapses. That wad of tinfoil separated by a sheet of paper can fail and stop the car just as good as any electronic ignition failure.
Oops, I was going for three strikes and I damn near closed out the inning. Again, these are my feelings based on my electronic and mechanical training and experience, but it just ain't like Henry made it, and it never will be.
