Went to my local Model A parts supplier today, and bought a complete valve train. Stainless steel valves, one-piece guides, keepers, and springs. When I looked at the valve guides, they didn't look like the illustration in the catalog. They are straight, and called "modern" valve guides. Call me dumb, but how in the world are they held in the block? Friction, Loc-Tite, or magic?? Here is what Bratton's catalog states:
MODERN VALVE GUIDES - This is a one piece straight guide. To install, insert the under cut end into the block first. The top domed end extends above the bottom of the dished hole about .030" use a 5/16 bolt about 3” long to tap the guide in. After the guide is in place, use a countersink with 1 degree angle to clean up any burrs, or hone the hole. The guide is longer then the stock ones, but there is no need to shorten them. Tappet clearence is .010" - .013" on a cold engine. Can only be used with moden style valves (9180), keepers (9310) and retainers (9330).
Can anyone enlighten me?
Thanks, Ron/IA
Thanks, Ron/IA
