Re: Modern upper plate-Reason why engine dies-backfires
Here is a post I made 3 years ago and posted on the old Ford Barn prior to May 2010.
The problem might be the lower plate and not the condensers.
08-08-2010, 09:42 AM #8
Benson
Re: Vrooom ... dadadada .... vroom .... dadada
Does the car have a modern upper plate with condensor on upper plate or have a condensor mounted somewhere else other than stock?
If so remove upper plate and look closely at the lower plate where the condenser screw is normally fastened to the lower plate.
You might find that the far end of the plate is shorting on the inside of the distributor housing.
This can be a VERY INTERMITTENT problem, mine went on for some time until finally enough paint was rubbed off that the problem went "solid" enough that I found it.
Uquote:
