May want to check out Bratton's kit. Nice powder coat, oil filled shocks (not gas), and the front to- frame upper brackets have outside rounded corners. No drilling except 2 holes in rear cross member ( similar to other vendors ). The fronts clamp to axle with evenly tightened allen head screws. Some sources debate virtues of gas charged vs. oil shocks. Gas may ride a little stiffer. As stated by others, Panhard bars on the fronts conflict with tube shock set up.
