I originally got this from 30Tudor
Electrical:
Motorcraft DC-1 Condenser
Motorcraft DP104 Point Set*
Points CS30 Echlin (original style)*
Points CS751 Echlin (new Ford style)*
Condenser FA5 Echlin*
Rotor FA3 Echlin*
Condenser-Mallory Dist MA3 Echlin*
Starter Brushes F502 Echlin*
Spark Plug 561 Champion (Wl6Y)*
Spark Plug 3X Champion (avail on special order)*
Coil (6 volt) IC9 Echlin*
Coil (12 volt) IC14 Echlin (w/built in resistor)*
Generator Cutout CU1 Echlin*
Alternator (12 volt) 71273SE OCA (one wire, internal regulator)*
Battery (6 Vo1t) 7200 Exide*
Battery (8 Volt) 8201 Exide*
Battery (12 Volt) 843578 Exide*
LED Lights
Tail light -*
http://www.unitedpacificind.com/storage/file10.pdf
Marker lamps -*
http://vehiclelight.com/clli.html
Light bulbs -*
http://www.superbrightleds.com
Bulbs
Taillight Bulb (6 volt) 63 GE*
Stoplight Bulb (6 volt) 1129 GE*
Taillight Bulb (12 volt) 89 GE
Stoplight Bulb (12 volt) 1073 GE*
