Steve Rinaldo
The reason that I posted earlier was that after a drive yesterday I noticed that the the car did have its normal power. and found that the spark was weak. I took the distributor cap and body off and found that that point gap was was quite large.
The points I was using was an Echlin CS 755 set. I found that the spring on the contact set was quite strong and seemed to to push the plate out of position causing the point gap to increase.
I searched the NAPA website and found there a several sets that work for these Ford V/8 engines. My local NAPA had the three different sets sent to the store so I could compare them. They were the, CS751,CS755 and the heavy duty set. What I found out was that the CS755 spring was quite strong and the tension on the heavy duty set was really strong. I went with the CS 751 {standard set}. I think this will solve my problem, if not I'll let you know. Some side info the screw size used on the point plat are 8-32. Steve
