"Having had / owned the 4 cyl chev...I would pass for the minimal gain, IMO. But it is an option, eh."
Not really true. Comparing the stock Chevrolet engine to a T engine with adapter plate and 28 head installed, not the same. A lot depends on how the adapter is machined. Jerns adapters came in different ratios (both T and A), I wish I had kept a file with the info. With the pop up on the T pistons, flat surface of the Chevrolet head, you can do a lot of things with the 1" thick adapter plate (you can go a little thinner), re designing the combustion space. RAJO's may have about the same squash space and some more (not all were made for the speed set, a number of them were sold as improvement for trucks) unless they have been decked with about the same size valves as the Chevrolet. My compression went from about 50 to 75/80 using the one I made, nothing special, just offset holes 3-3/4" in diameter. For a stock crank that gain was ok. Any more then the bottom end would need attention. The 2ed You-tube video is mine. To add; mine was made so the stock T overhead valve type gasket could be used on one side and stock Chevrolet gasket on the other. The water outlet on block and heads don't line up so there is an adapter to take care of that.
