TDO Senior Member Apr 5, 2015 #1 How do you check the rotor button gap to distributor body contact points. 025. When using a modern distributor cap.
B Big hammer Well-known member Apr 5, 2015 #2 Would silly putty on the cap points and then turn the rotor thru them, maybe then you could gauge the gap? Just a thought never done it
Mitch//pa BANNED Apr 5, 2015 #3 if it is not rubbing dont worry about it... this is an over stated spec IMO
