Ed Saniewski
I am having a problem with my ignition system,engine ran for 5 min. and died. The dist. gives a spark when i open and close the points, but when assembled the body and rotor,I don't get a strong spark to the spark plug. I have tried 3 dist bodies and rotors and caps, and 2 coils and coil wire. . I switched out the dist for another modern point and con. and it ran for 5 min. then died. finally we dug out an old dist. with original points and it runs great.the spark now jumps 1/2 inch and bright. How do I test the modern condenser to see if it is bad? would this give me a weak spark? What would cause 2 condensers to go bad, could a short somewhere in the electrical system damage it? I will go out today and get another modern condenser and try again.
