ed thibodeau
Bought a modern bendix and built a compressor tool (copying the one in the catalogs) and tried to compress the bendix to get the set screw out but it wont compress at all. What am I doing wrong. Thanks Ed.
I have never used a compressor. I do not remember exactly what I did,but here is what I would suggest. Get a short piece of 1 1/2" pipe,grind a slot in the end so you can get to the screw. Put it in a vise and backout the screw enough to hold the sleave back. Once screw is out you can put it on the shaft,hold screwdriver in tight,tighten screw and sleave will go out,you are done. I keep the screw out if I take an extra in my car.
Hope this helps
John
Just think of all the fun you will have if you ever have to remove it on the road. Yes, the new style drives do break/jamb. I have had two 'moderns' fail, now I'm back to good 'ol reliable- Bendix drives.
Sorry to hear of your bad luck ! Well, mine could go after all these years, and I would still feel good towards its operation/longevity.
And, Pete had a good 'plan B' suggestion...which I have used, i.e.-gear drive! On 12V it will crank out about 1.5 hp
! If good battery, I might even drive it home on that starter...if something else lets go.
