Model TT truck
Mike
Good morning,
A friend is dropping off a 1919 TT Truck for me to work on, my problem is it will not fit into my garage. Does anyone make a stand that I can use with my car dollies if I remove the wheels ? Any help would be appreciated.
mike
Good morning,
mike
Mike,
You can make wheel dollies that will support the frame
from casters - wood - bolts ....
You can try using commercial wheel dollies fastened to the
drums - not sure how good that would work.
Jim
Im just thinking outside the box, but couldnt you make 4 round discs out of 2 inch wood and put them on the axles.
I let a little air out of the tires and it fit into garage, tight but it is in. I don't like jack stands and wheel dolly combo, I saw a close call when a Model A almost fell off the stand/dolly.
Mike
Mike, it would probably be a good idea to remember to drain some air out of the tires before you exit the garage when you are finish with the repairs.
Something like that is easy to forget. Maybe a note taped to the steering wheel?
