Model T year id
Shelbycsx
Try to find out what year this model t is. There's a number stamped in the wood BF31818. The motor number isn't legible. Electric starter, metal seat frame, coil box under dash. I'm thinking it's an 18
The cowl is 23 or 24 closed car. There should be a casting date on the same side as the engine number - it will be back & down from the water inlet.
Great looking tractor. Are the front wheels cast iron?
The casting no. should be about where the one in the picture is. Some later blocks had a round no. insert. The last no. is the year - this one being 1917.
Sometimes the serial number can be brought back by using a liquid dye penetrant used by piping contractors to detect cracks in piping systems. The slightest indentation will show up.
Just a thought.
