model T running board aprons ?
harvest
I have a set of splash aprons I think from a model T? they measure 63" at the longest length. can anyone identify what years used these? thank you for the knowledge. :)
I would say they are 23-25. The two slotted holes that bolt to the running board were not until then. The MTFCA Ford Encyclopedia states "Same as earlier boards but drilled differently." I think that refers to these holes.
Also "Similar to prior style but patterned to fit wider hood clash strips when higher radiator appeared about June 1923. (Had hole for hood clip.)" Yours have 2 holes near where the front meets the frame and I believe that is what this refers to.
My Dad bought a couple sets of NOS Aprons for Model T's from the Old C.O.D. Garage in Minden Nevada when they went out of business , they are setting in the barn , I will take some pic's . one set is shorter than the other , but I need to measure them and post some pics. hopefully someone can use them.>>>>>>>>>Pic is of my Dad ( passed ) and his 17 T , taken in late 90's
15max, thank you for identity.
