Neil Mylar LakewoodCA Well-known member Jan 8, 2012 #1 Have any of you seen this type of set up. Not a professional job, but I wonder how good it might run. Regards, Neil Attachments Model a pop out carbs 007.JPG 116 KB · Views: 42
T tmodelman Well-known member Jan 8, 2012 #2 With that long drop leg on the intake, so the big Model A carb clears the frame rail, at least the gas flow to the bowl would be good
J Jalopy Tin Senior Member Jan 8, 2012 #3 I use a 26-27 vaporizer intake upside down with a home made connection to the Tillotson X carb. Runs perfect! Attachments !cid_923.jpg 44 KB · Views: 43
John Otis Senior Member Jan 8, 2012 #4 I saw a similar A carb setup once but it was made from plumbing fittings. One of the best running T's I ever saw had a homemade intake and a big old carb that had come off a big 2 cylinder combine engine. Wisconsin I think.
