Model T fenders
Rootleib makes the best, and most parts suppliers are vendors of his fenders and hoods. Good stuff I've used his products for years.
What I am wanting to do is Make a TT into a T. I want it to look like something that could have been built (as far as I know Ford never built a closed cab T truck).
I have the cab, hood and rad shell off the TT and a bed from a T rpu ('26/'27). I want to run '27 style fenders. Fronts I saw but I did not see RPU specific rear fenders, splash aprons or running boards, Are these model specific or are these parts shared with another style body? Thanks
('26/'27). I want to run '27 style fenders. Fronts I saw but I did not see RPU specific rear fenders, splash aprons or running boards, Are these model specific or are these parts shared with another style body? Thanks[/QUOTE]
26/27 T roadster, coupe & pickup share the same rear fenders, running boards & splash apropns are the same on all models.
If you are going to use these on a TT you might want to check to see if there is room for the larger tires - both diameter & overall width.
