You could add a hand pump to pressurize the fuel tank only when and only as much as necessary. Requires some creative plumbing and a cap with no hole, and a relief valve somewhere but better than an electric pump over pressuring the system all the time. I would think a rich mixture would occur as well as flooding during periods of low manifold vacuum or when the engine is shut off. My T has the tank mounted up pretty high in the back and I get a drip from the carb with more than 5 gallons in there, which barely registers at all on a pressure gauge. Whenever I put that much in the car I have to shut the valve between the carb and tank when parked to avoid a little gas puddle. My model A with a down draft v8 carb uses an electric fuel pump and the regulator had to be dialed all the way down to barely over one pound of pressure.
The other method, which admittedly I have yet to try, but plan to, is a rheostat or potentiometer in the wiring to trim back the power to the pump and thus reduce the duty cycle and pressure created. I read about it in a tinkering tips and also a ford barn luminary suggested it at one point as well for any early ford. Seems like adjusting the volume and pressure on the fly, based on terrain and traffic would give the optimum service. Good luck and hopefully keep us posted on any changes, better or worse! -Chris, in Boulder
