billjones
I don't want to get into to much trouble posting into multiple forums here, but this tour has a bunch of T's as well as new fords, like 28,32, 37, 38 and so on.
It's Ken Austin's collection who is probably best known to the readers of the flat head forum. He designed and marketed many flat head 'heads' and multi-carb manifolds. He still manufactures them as well.
copied post:
I posted this before (but not here) and received some great suggestions, here is the same tour but with a lot added, check out the turntable shots and all the new drivers POV panoramas. Most had trouble figuring out what to do so I created a tour map that should help get around. The panoramas will turn but it's not automatic, you have to turn the pano with the mouse or click on the circular icon. Have fun and give feedback. This is my resume to be submitted to museums, car, air and train. So feedback is very important to me.
I have also added more shots in the image galleries.
M work consist of developing virtual tours, I had the opportunity to do a excellent collection and just wanted to share with all. There are numerous way to navigate but to view interiors and the standard image galleries you need to use the drop down menu in the upper left.
http://rhmpano.com/tours/kenaustincars/
I can see I have visitors.
The problem I have is not knowing what you did out there. So it's hard to either anticipate what you want to look at, or if you did look at it.
Every car out there has it's own image gallery.
There are now 23 interior panoramas (drivers view). Use the tour map to get around.
One car is on a turntable and you watch it go around in circles, one revolution with the doors closed, one with everything open. That consisted of 192 separate shots.
So what did you see and what didn't you see, and if not, why not? All links work on my end, but maybe not yours.
If I don't know it's broke I can't fix it.
That's what I need to know.
enjoy.
copied post:
enjoy.
