Model BB vin number
Marshalfire
New member
So, I have a frame with a vin number BB 3 5072995Y!
What is the 3 indicate, and what is the Y at the end mean?
What I have found by the 5072995 that it was produced sometime between 1932 and 1934.
Nothing on the 3 or the Y though!
The frame is bent but would like to know the facts about it even though I do not plan on using it!
Any help would be appreciated!
Thanks!
Welcome to fordbarn. You posted in a section intended to be a place to test the site, usually for testing posting pictures. Leave it here (why spend the money to delete it?) but also post it here: https://www.fordbarn.com/forum/forumdisplay.php?f=4
The BB prefix goes to a heavy commercial vehicle, I assume your frame is heavier than a passenger vehicle. The basic serial numbers started with 5000001, I assume to avoid duplicating the Model A numbers. I have never seen the 3 or Y you are asking about. The best source for information on the basic 7 digit number is "The 1932 Ford Book" (see https://shop.efv8.org/collections/ford-books/products/1932-ford-book-softbound-all-new) which says your frame had an engine installed that was built early 1932. You can also find the information here: http://www.fordgarage.com/pages/ABenginenumbers.htm#C1which places the engine/transmission build at May 1932.
When you post also update your profile to include your general location, that may be part of the answer.
Charlie Stephens
