Model B transmission
Jack,
You should be able to bolt the Model B flywheel cover to the back of the Model A engine and then bolt them both to the transmission. You will have the flywheel exposed unless you fabricate a cover since it is covered on the bottom in the Model B installation with the back of the oil pan. You should be able to use the Model B front mount on the Model A engine. Remember that the Model A does not have a fuel pump and you will have to use an electric fuel pump. You will also need to run the Model B flywheel as the Model A flywheel will hit the transmission case. So the answer is yes, but please don't put a Model A engine in a Model B car.
Charlie Stephens
