Model B timing cover vs model a
32forddump
I have just checked the 1932 Bible and don't see any pictures of the model b timing cover. Is there a difference between the B and A cover and what is it?
The easiest way to tell the difference is the area where the timing pin is inserted into the cover. On a Model A timing gear cover the raised area surrounding the hole is round and on a Model B cover, the raised area is oval shaped reflecting the initial advance of the Model B ignition. Once you know that difference, the other timing cover that you might encounter is that of the '33-'34 fours. The raised area around the timing pin hole reverted to a circle, but the generator mounting location is noticeable set back and the spacing of the motor mount bracket attachment holes along the bottom of the front of the cover have a very unique spacing compared to either the A or B covers.
I've added an out-of-focus photo of a Model B cover where you can at least perceive the oval area around the hole for the timing pin and a somewhat better photo of the very different '33-'34 timing gear cover. Sorry about the photo quality.
Two photos of a '33-'34 cover and one showing the oval area on a Model B cover. I believe I read somewhere that a small number of Model A covers were made from the Model B casting by locating the pin at the bottom instead of the top of the oval (not shown).
Charlie Stephens
cas3 is correct, you can find much better photos of the three major U.S. versions plus more on that site.
Charlie,
You're correct, that late Model A variation shows up on the fordgarage.com site.
Also note that you cannot use the B timing cover on a model A or vice versa.
I believe you can as long as you find and alternative to find top dead center or initial timing for a B distributor. If you're running an A distributor in a B block you need the A timing cover.
