Model B throw out hub, same as the model A?
jerrod1932
I'm using a 1933 model B engine 4 CYLINDER engine, does anyone know if the model A throw out hub (this is the cast hub that holds the throwout bearing,) is the same for the model B as is used on the model A? THANKS
If you are using a "B" Transmission, you use the V-8 style Hub.
Model A Hubs are only for Model A Transmissions.
Chris
