i dont have any bafffles around pump.dip stick is the same match with a model coupe i have,i'm sure as you say it nearly held 5 quarts.i just went for a drive and paid closer attention to oil pressure and it declined more as i was braking before i turned.it went down to 0 to 1 lbs on braking and worse on right turn,unless braking was the culprit to start with.also the engine is same level as other engine.the pressure picks right back up on acceleration.may be i have a model oil pump in it and that is a problem.my last question is will this momentery loss damage the engine?only 300 miles on it and was'nt noticed until i added the guage.sometimes what you don't know will hurt you.any advice,or ideas will be appreciated.thanks for replying.
