You are correct forever4; doesn't the "C" indicate a 33-34 head ? The problem with using a 3 bolt water pump is locating one, hoping it isn't cracked, anf finding parts to rebuild.
Ron
Ron,
The "C" indicates a 1932-1934 head. This probably occured since the Model A police head had a "B" on it.
Charlie Stephens
Is there such a thing? Would like to run the stock water pump (3 bolt) with a higher compression head on my B. Everything I see has 4 holes?
Thanks, Mike
No need to buy the expensive model B waterpump rebuild kit. The model A pump uses the same rear bushing, packing nut and front bearing. The model A shaft is longer and can easily be shortenen to work with the 32 or the 33-34 water pumps. If a person has the model B pump houseing and impeller all that they will need is the ability and model A water pump parts, no big deal.I believe the '32 water pump is now fully available in repro, and the '33-4 unit can presumably be rebuilt using the '32 innards with shaft shortened. No idea if the repro stuff is good quality or not.
