Model B Fuel Pump
Am I correct that you see the two components as incompatible because they typically occupy the same physical space?
My guess is no although you could probably install a remote filter kit. Or make your own like one member did on here. I think it was Al in NY?
I have the Specialty Motor Cams Oil Filter Kit for B and run the stock B pump. It is very well made.
I have two Stipe ( Specialty Motor Cams) Model B filter Kits.
Other manufacturers of filter kits make use of the unused fuel pump opening on side of B block to return the oil to the oil pan from an external mounted oil filter.
In these cases you can not run a stock B fuel pump with this oil filter.
My remote full flow oil filter dumps the filtered oil into the valve chamber.
The remote full flow oil filter dumps the filtered oil into the valve chamber.
This is filter I spoke about in previous post for Model B which uses (that is covers up) the fuel pump "port" to mount filter.
Looks maybe home brew.
Also has bypass valve that dumps to timing cover.
Filtered Pressure oil goes into stock Model B engine "oil Galley".
